Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 141
Thread: MK1 Deisel for the Sh#tbox Rally... a build thread.
  1. #101
    Orange, NSW
    I think that was the tyres :\
    I recon we could throw in 500kgs and it'd ride great. only problem would be the clutch...
  2. #102
    Jun 2006
    Orange NSW
    Yikes!
  3. #103
    Orange, NSW
    so we fixed that problem...
    Random springs, pedders struts (found among my Skyline spares) some taper lock sleeves, and a bit of ingenuity... we have height and we have ride comfort... hopefully...
    Current rear height with sponsor mock up
  4. #104
    It might be safer to weld a tube that just fits inside the spring, on the bottom spring mount. Something about 60mm high which would make sure the spring doesn't slide off the mount. Do the same for the top of the spring and it will never fall off no matter how rough the roads are.
  5. #105
    Orange, NSW
    Hard to see on that pic, but we're using the original spring mounts, top and bottom, and they fit really well aside from the tail of the coil at the bottom of the spring... it's fully capsulated at full droop, which is 50+mm from weight bearing and settled, we have welded a small tab to lock in the bottom coil on the factory spring mount.
  6. #106
    Jun 2006
    Orange NSW
    Looking good, big fella. You'll have to get it wheel aligned, now! Haha.
  7. #107
    Orange, NSW
    yep, it'll be sorted when the bigger tyres go on, it won't go far until then.
  8. #108
    Orange, NSW
    *sigh* this is why I never try to leave the old man unsupervised... he busted our other rear shock, so back to square one on the rears after 3 days of mucking around, at least someone has been kind enough to donate me some new rear struts that we can mod, AGAIN.
    Trying to sort fronts now, there was more oil in the upright than in the shock of our original sets... can anyone help out with inserts? There isn't much in the country from new.
  9. #109
    Boronia VIC
    I might have some gabriels, I'll have a look tonight.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  10. #110
    Orange, NSW
    Much appreciated
