Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Mk1 Chin/Dams
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by gtimk5
    No problems at all James. We are all on here to help out or answer question. Thats what the forum is all about, and to keep the interest going!
    Its not hard to put a mk2 spoiler on. The major advantage is that it is flexible! I cut out the dummy brake sections and ran some pieces to direct air towards the front brakes. You do have to drill some extra holes, especially on the rear trailing edges. I agree, it does look a little bit "wonky" in some shots but it also copped a bit of a hard time. On my old mk2 the outer corners used to touch the road on very hard cornering! Just guessing the hieght would be around 90/100 m/m deep. I mounted it slighty higher than the original. Cheers, Andrew
    Sweet thanks very much... I'll have to get one...
    Sep 2005
    Maroubra Beach
    just bought a large duckbill for Raus.
    Whats the best way to mount them into the standard holes i have in the front?
    5 x M8 bolt's, 10 x panel washers & 5 x M8 locknut's. Strong as!
    Nov 2005
    Quote Originally Posted by golfworx
    Yep that sounds good.
    I'm suprise those things don't get ripped off with the amount of head on air flow...........best looking one regardless.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
    Sep 2005
    Maroubra Beach
    is there one kind or what size am i meant to get?
    The GTI one's are stonger than the small duckbill's!
    You can also repair the GTI mounting's if broken with metal plates & pop rivet's
    They will actually bend & split the metal around the hole before breaking. Well that's in my case. Depend's on what you hit I suppose!
    I've only ever replaced one GTI style & before that, I replaced 4 smaller ones due too wondering bunny's etc.
    The M8 refer's to that thickness of the bolt thread. 8mm.
    I think from memory, I used 5 x Flanged headed M8(8mm thick & 1.25 pitch thread) x 25mm long bolt's with matching locknuts & 5 x fat panel washers (1 on every bolt/nut set).
    Don't look too far into the rust situation!
    Sep 2005
    Maroubra Beach
    I think from memory, I used 5 x M8(8mm thick & 1.25 pitch thread) x 30mm long bolt's with matching locknuts & 10 x fat panel washers (2 on every bolt/nut set).
    cheers man!
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    Sep 2005
    Maroubra Beach
    i have heard i should use plastic bolts as the dam needs to flex.
    Is this true?
    Nov 2005
    Quote Originally Posted by XXX-1.8T
    Is this true?
    Hey mate, I meant you shouldn't use steel screws with those plastic gromets. But steel bolts with steel washers are fine.
    Sep 2005
    Maroubra Beach
    sweet man!
