Sweet thanks very much... I'll have to get one... :)Quote:
Originally Posted by gtimk5
Printable View
just bought a large duckbill for Raus.
Whats the best way to mount them into the standard holes i have in the front?
5 x M8 bolt's, 10 x panel washers & 5 x M8 locknut's. Strong as!
Quote:
Originally Posted by golfworx
Yep that sounds good.
I'm suprise those things don't get ripped off with the amount of head on air flow...........best looking one regardless.
is there one kind or what size am i meant to get?
The GTI one's are stonger than the small duckbill's!
You can also repair the GTI mounting's if broken with metal plates & pop rivet's
They will actually bend & split the metal around the hole before breaking. Well that's in my case. Depend's on what you hit I suppose!
I've only ever replaced one GTI style & before that, I replaced 4 smaller ones due too wondering bunny's etc.
The M8 refer's to that thickness of the bolt thread. 8mm.
I think from memory, I used 5 x Flanged headed M8(8mm thick & 1.25 pitch thread) x 25mm long bolt's with matching locknuts & 5 x fat panel washers (1 on every bolt/nut set).
http://xs307.xs.to/xs307/06400/DSC00521.JPG
Don't look too far into the rust situation!
http://xs207.xs.to/xs207/06400/DSC00523.JPG
http://xs207.xs.to/xs207/06400/DSC00527.JPG
cheers man!Quote:
i have heard i should use plastic bolts as the dam needs to flex.
Is this true?
Quote:
Originally Posted by XXX-1.8T
Hey mate, I meant you shouldn't use steel screws with those plastic gromets. But steel bolts with steel washers are fine.
sweet man!
