Results 11 to 20 of 21
Thread: Mk1 cant take the heat.
    Only problem I had with overheating on a mk1 was dirt on the OUTSIDE of the rad so be sure to clean it well when you reverse flush it.
    May 2006
    Maryborough Vic
    Talking
    yep drove mine to work and back all the time
    no trouble at bar one time when i lost power to the cooling fan
    and we get mid 40's for a week at a time
    as every one has said flush out, thermostat and good coolant and you can't go wrong
    Aug 2008
    SYDNEY
    my never goes past a third on the gauge, it has had a reco radiator put in however, just flush yours out see if that helps. im running it on water also. probably should put coolant in for the summer....
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Feb 2007
    Quote Originally Posted by AUC-05L View Post
    Ive researched and coolant acutaly doesnt help reduce the temp, water is much better. It prevents corosion and increases the boiling point but thats about it.
    MK1 GLS 3door
    A4 B7 2.0T
    Feb 2008
    Melbourne.
    drove mine back from the mechanic(who'd had it for 3 weeks) this morning..whilst now tuned well, a few carby leaks and throttle spindle sticking, but the temp. never moved beyond the 1/2 way mark on the guage..thermatic fan running well, which I noticed after switching motor off at home maybe the Mk2 alloy radiator really does the job ??
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Jun 2006
    Orange NSW
    If the throttle is sticky put i nice big return spring on it. That's how i had it set up. I'm surprised the carbie is leaking. I never had that problem. How's she go? Happy with it?
    I had a Mk1 diesel radiator in my Mk1 (well, i still have it..). Never ever had problems with heat. Just used normal run of the mill coolant.
    Feb 2008
    Melbourne.
    man it goes like the wind and the sound is awesome !!!
    Jun 2006
    Orange NSW
    Quote Originally Posted by dubai gti View Post
    Ahh good. The G grind cam combined with an IDF make for a nice note.
    Dec 2007
    Somewhere in Melbourne, Victoria
    Mate, all the things here are valid symptoms of overheating and I commend them all. I recently replaced the thermoswitch in my cabby (1.8ltr CIS GTI engine) with a lower temp kick in one.
    The Mk2's had two speed fans that seemed to do the trick, this second stage fan sounds like you are landing an aircraft but it works.
    Also worth checking is the timing and tune of the engine. If it is out of tune or timing it has been known to cause excess heat.
    Finally, oil. Oil will assist in managing temperature so make sure you are topped up with a good oil that stays together in the heat.
    Always a frustrating task but once you get to the bottom of it your car will thank you!
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Feb 2008
    Melbourne.
    drove it in peak-hour this morning (on the way to B&M Fuel Systems)with idle b/n 2-2.5k...wasn't too happy and died a couple of times but came good eventually without a complete stall...anyway B&M is putting a kit thru' the carby, fixing my dodgy return spring set-up (oh I wish I had my tools...which are still in storage in Tweed Heads) and fitting a new accel. cable and pedal grommit (thanks to Frank @J&F)
    Pick up is tom. and more in store b4 Sunday's show!!
