Have a word with your local VW mechanic or wrecker. VW made some wheel bolts 15mm longer than the standard MK1 to suit other models. I got a set off Pete at the Canberra VW Centre but you should be able to source some locally.
Hi all,
recently bought a set of Cabby wheels for my Mk1, however the wheels require longer bolts...any ideas where i can get a set?
Cheers![]()
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
pretty sure there is a Audi, or even a BMW that uses longer bolts from factory... try wreckers?
<space for rent>
later bolts fit and are longer. mk3 bolts for instance.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Thanks mate, makes it easy to source...cheers
