Results 1 to 5 of 5
Thread: Mk1 Cabriolet Wheel Bolts
    Oct 2006
    Hi all,
    recently bought a set of Cabby wheels for my Mk1, however the wheels require longer bolts...any ideas where i can get a set?
    Have a word with your local VW mechanic or wrecker. VW made some wheel bolts 15mm longer than the standard MK1 to suit other models. I got a set off Pete at the Canberra VW Centre but you should be able to source some locally.
    Sep 2009
    Chillaxing in Tas
    pretty sure there is a Audi, or even a BMW that uses longer bolts from factory... try wreckers?
    <space for rent>
    Gosford Central Coast NSW
    later bolts fit and are longer. mk3 bolts for instance.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oct 2006
    Thanks mate, makes it easy to source...cheers
