Results 1 to 9 of 9
Thread: Mk1 Cabriolet - does not want to start!
    Mar 2009
    Melbourne, Victoria
    Hi all,
    I am having trouble starting my 1991 Cabriolet. When I turn the key the car tries to turnover but it can never quite do it.
    All this started when previously when driving the car, it would just turn off. After turning off during driving, it would not restart for about 5 mins and then it would be fine. This started happening more often, to the point where it just doesnt start anymore. Battery is ok and fuel pump seems ok too. I have heard that it could a relay, but I don't have a Bentley so I do not which relay is the fuel pump one.
    I have tried to sell the car as I have bought a MK2 GTI and would like to invest some money into this now, but a car that is not running seems to be hard to get rid of. I have decide now to try and fix it and get it running again as its a nice car.
    The car has been sitting in the garage at my dad's for a while now as I haven't had time to try and fix it.
    Has anyone else had similar issues and does anyone have an idea what it could be?
    Thanks in advance.
    Vildan
    1991 MK2 GTI
    Dec 2007
    Somewhere in Melbourne, Victoria
    Depends on whther you have Digifant or CIS fuel system. If it's CIS like my 93 cabby, the relay is (from the bottom of the fuse box) 2nd row and second from the left. They are about $40-$50 to replace. Fuse should be 5th from left (15 amp).
    If in doubt check out Cabby Info - Home
    they are a wealth of info
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Mar 2009
    Melbourne, Victoria
    I am pretty sure its a CIS (K-Jet). I believe all aussie delivered cabs were CISs.
    Thanks for that website, there is some great info on it.
    Is there a way of checking that the relay/fuel pump is working?
    1991 MK2 GTI
    Jun 2007
    Eastern Suburbs Melbourne
    you should be able to bridge the relay.
    Ie take it out, and connect a piece of wire into where the relay normally sits. Can't remember which two spots it is, but it should provide constant power to the FP.
    So bridge it, let it run for 2 seconds, and try and start it. IF it doesn't start, take it out again, otherwise you'll flood it
    i like volkswagens
    Dec 2007
    Here's one idea from VWVortex forum
    VWVortex.com - Everyone with CIS needs one of these.
    Bentley Bible says to bridge terminal 30 (battery power) to terminal 87 (switched relay output). Maybe a strand of wire with a male crimp terminal at each end with a simple on-off switch might do the trick.
    Mar 2009
    Melbourne, Victoria
    I found that thread as well. I haven't had time to try anything yet, I am gonna try a few different things tommorow and see if I can diagnose the problem.
    I am not sure what else it could be really...
    1991 MK2 GTI
    Dec 2007
    mine had the same problem a couple of years back. I tested everything and then the relay (duh!), a new relay and the worlds aligned again
    Mar 2009
    Melbourne, Victoria
    Where did you geta new fuel pump relay? What number is on your relay? My one says 62 I think.
    1991 MK2 GTI
    Dec 2007
    I got mine in Brisbane back in the day, but I am sure the guys at Volkspower in Burwood can help out.
    VW Volkswagen used cars and car parts for Beetles, Golfs and Kombis from Volkspower Melbourne Australia
