Results 1 to 6 of 6
Thread: Mk1 cabby running hot / squealing
    Feb 2010
    Any help would be appreciated greatly.
    I had an issue that my car would overheat within 5 minutes of driving
    After replacing my waterpump, thermostat, upper and lower radiator hoses, expansion tank and cap, and the sensors. Also replaced the belt.
    My still runs hot after 10min of driving
    Mk1 cabby running hot / squealing-uploadfromtaptalk1394433641894-jpg
    Now my car has started squealing when I accelerate.
    If you could throw some suggestions at me, that would be great. Im all out of ideas
    Sent from my GT-I9507 using Tapatalk
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Most likely clogged radiator.
    Feb 2010
    Thanks. I guess it would be the only part I havent replaced.
    Any ideas on the squealing? Could it be the belt/alternator
    Nov 2009
    Squealing, loose alt belt, would explain temps too
    Jan 2012
    St Albans, Victoria
    Try to rub a bar of hand soap on the belt, see if it changers the sound, if not could be your new water pump? Or one of the other bearings on one of the other pulleys?
    Jun 2008
    Hobart, TAS
    You may also have some air trapped in the system, and as previous poster said impeller may be clogged or fouling, which is putting strain on water pump, hence the squealing belt
