Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: MK1 brakes
    Sep 2005
    MK1 brakes
    Another question about mk1s.
    I find that my brake pedal comes out along way and needs to be pushed in heaps before the car starts to brake. Is there a way to adjust this so it sits level, maybe the accelerator needs adjusting out also?
    Also the brakes feel really weak im scared someone will stop suddenly and ill go right up them! Is there a way to get more power from the mk1 brakes? Any ideas are welcome, all help is much appreciated.
    Thanks in advaced!
    May 2006
    Maryborough Vic
    Talking
    the first thing i would do
    is blead the brake flush out all old fluid
    with nice new stuff
    and then adjust rear brakes that would help
    peddle feel and amount of travel
    and there is always upgrades!!!
    Feb 2006
    Devonport, Tasmania
    I actually have a D clamp that stops the brake pedal coming up so far. Its clamped on the steering rack. I think. I cant check now but ill have a look 2moro.
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
    Jan 2006
    Ballarat, Victoria
    Yeah, I was thinking adjust up the rear brake shoes - brings the pedal up.
    Also what pads are you using? Genuine are supposed to be good.
    Feb 2007
    There was a thread some where here that showed how to do a good break upgrade using holden calipers and drilled-vented disks. I couldnt seem to find it again. I remember it saying it was cheap and stoped realy realy well.
    Can anyone remember it?
    MK1 GLS 3door
    A4 B7 2.0T
    brackie Guest
    Search results
    By typing "camira brakes" I got this:
    http://www.vwwatercooled.org.au/newf...searchid=48278
    I seem to remember a detailed description somewhere. Maybe this will be a prompt to someone and we'll get it again.
    syncro Guest
    If you're going to change calipers etc, it would be better to go GTI. See Matt (Golf Loon) if he can get some for you.
    Sep 2005
    Thanks guys for all the input! Very interesting all the things you can do, camira sounds cheap! But the car has recently had new brakes done front dont know about back. Think bleeding them which ill have to look up in my manual when i get it. and maybe adjust the drums / rebuild them. Booster might also need a change.
    Any other ideas at the moment i dont think ill change callipers. till brakes truely screw up or a bigger engine is fitted!
    brackie Guest
    Adjusting wedge.
    Mate.. The rear brakes are supposed to be self-adjusting, but they ain't.
    http://www.vwwatercooled.org.au/newf...ighlight=wedge
    Jan 2006
    Ballarat, Victoria
    I adjust the wedge on the rear brakes whenever I service the car or when the handbrake travel is getting too much.
    I take the wheel off and rotate the drum until the bolt hole aligns with the spring hole in the wedge. then I insert a long pointer/awl and pull down the wedge.
    the Mk1 LS I used to have had the wheel type adjusters, accessed from the back of the drum.
    Either way, I reckon adjusting the brake shoes is the first step in dealing with that excess pedal travel.
