Mk1 Brakes are designed to put the fear of God into you, but they will stop the car if you push em hard enough.
Linkage bar across the engine bay adds vague feeling, check all the links for play
Rear brakes can be adjusted as above, or replaced with drums from a Golf CL or SEAT Cordoba which are bigger and slightly better designed. No other mods needed, just bolt on ;)
