Hi all the mk1 brakes are not really working as they should. Been looking at doing a brake booster/master cylinder upgrade, however trying to find a mk2 booster is a real pain. I'm just wondering if there is anything else possibly that would work in place of the mk2 one
I presume so everything seems to be standard. Cars a cabrio. i did see something about mk3 bits but never seen any threads saying what to use
Let me know if you're still after a MK2 booster.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Mk3 rears or Cordoba & maybe Ibiza fit with their stubs
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
Mk3 booster with master cylinder will bolt up perfectly! You just need to change the brakes light switch to be on the pedal instead.
Mk3 drums might fit the mk1 stubs, but you'd be better off just getting the mk3 stubs with the drums for a hassle free install.
If everything is servicable then try new Front brake pads that are a modern grippy compound (high CoF)
Just make sure they do not require warm up for road use
Mk3 booster and servo will fit, bit you need to cut the input link and then thread it to receive the Mk1 'yoke' style link.
However, if you have leaking wheel cylinders or calipers, bulging lines, old crappy pads/shoes, then it's not going to help.....need to look at the whole system to ensure they all work together
Is there all the boosters in mk3 all the same size? Seen what's involved and looks pretty straight forward
