Results 1 to 9 of 9
Thread: Mk1 brakes
    Sep 2016
    Perth
    Mk1 brakes
    Hi all the mk1 brakes are not really working as they should. Been looking at doing a brake booster/master cylinder upgrade, however trying to find a mk2 booster is a real pain. I'm just wondering if there is anything else possibly that would work in place of the mk2 one
    Quote Originally Posted by nickosy View Post
    Make sure the rear drums are adjusted up properly.
    Can I assume that you have the 239mm no vented discs on it?
    I'd probably be looking to the UK for parts.
    I forget, as it's been so long since I owned one, if the MK3 servo and master cylinder fit.
    Sep 2016
    Perth
    I presume so everything seems to be standard. Cars a cabrio. i did see something about mk3 bits but never seen any threads saying what to use
    Let me know if you're still after a MK2 booster.
    Paul
    Jan 2006
    Lowood Qld
    Mk3 rears or Cordoba & maybe Ibiza fit with their stubs
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Feb 2013
    Melbourne SE
    Mk3 booster with master cylinder will bolt up perfectly! You just need to change the brakes light switch to be on the pedal instead.
    Mk3 drums might fit the mk1 stubs, but you'd be better off just getting the mk3 stubs with the drums for a hassle free install.
    Nov 2014
    If everything is servicable then try new Front brake pads that are a modern grippy compound (high CoF)
    Just make sure they do not require warm up for road use
    Feb 2006
    Melborune, VIC
    Mk3 booster and servo will fit, bit you need to cut the input link and then thread it to receive the Mk1 'yoke' style link.
    However, if you have leaking wheel cylinders or calipers, bulging lines, old crappy pads/shoes, then it's not going to help.....need to look at the whole system to ensure they all work together
    Sep 2016
    Perth
    Is there all the boosters in mk3 all the same size? Seen what's involved and looks pretty straight forward
