Results 1 to 4 of 4
Thread: Mk1 brake balance with cordoba drums
    Apr 2006
    Melbourne, Victoria
    Hello all,
    I have cordoba drums on the rear of my Mk1 4 door and a larger MC/booster. Recently I have had the joy of commuting along a very windy road and noticed that the car is very taily when braking hard for a corner. If I trail brake it can easily oversteer. I suspect that the cause is the rear brakes. What pads are available for the Mk1 that are more "aggressive" such that i can even out the brake balance using front pads? THe car has stock diesel front brakes but I have GTI calipers that i can install.
    Cheers, Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Sep 2009
    Chillaxing in Tas
    GTi front calipers and vented rotors will do it
    Thats what i got and its spot on with Doba rear brakes
    <space for rent>
    Gosford Central Coast NSW
    yeah, the gti front setup is the go, but unfortunately is becoming hard to find. Cabrio counts as GTI too, although some are not vented, they still bite harder than the standards.
    Even with the GTI ones I think the bias is a little bit to the rear... but not much. You could modify a mk3 proportioning valve to stick on to the rear axel pretty easily.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oakleigh VIC
    Use the inline prop valves out of a 1400 Ibiza in the rear brake lines.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
