Hi scoot13,
Try using the search function on this forum it will bring up a lot posts on this subject, check out some peoples builds who have done this conversion before, you will find them pretty informative.
Hey just a quick question
How easy is it to fit a 5speed in a mk1
Do I need different brackets
Do I need different drive shafts
Hi scoot13,
93' MK1 cabriolet
Box, shifter and mounts!
Go down and talk to the guys at Camden GTI. They'll have lots of advice and the bits you'll need.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Out of interest what is the going rate for box/shifter/mount ready to go on the second hand market
Box is easy enough to get since all Mk3 manual boxes are 020 (not vr6). Be aware that Mk3 020s have 100mm drive flanges so either new drive shafts are needed or the flanges changed to 90mm. Mk2 gti is a common source for the gearbox as well, complete with 90mm drive flanges.
The linkage can be made by simply extending the shifting arm using a welder and some plate. The required pull rod can be bought new for pretty cheap too (vwheritage).
The mount is the difficulty, because the only ones that work are out of a late model cabby or a gti. There is someone on here who modifies 4 speed mounts but I can't remember who...
Easiest way is to keep an eye on the parts for sale section for someone selling the whole kit. They usually go for about 250-300 bucks
Gldgti makes the mounts. Its posted in the stickies buddy
Sent from my SM-G900I using Tapatalk
Cool, I have a full kit sitting there as I am going 02j, one day will post it in the for sales but need to organise myself! (Probably no good for the OP as it is in Melbourne and it would cost $100 for freight)
Thanks for the help
Will pop over to Camden gti and see them
New to this forum stuff
Will have a look
Thanks
