Results 1 to 10 of 13
Thread: Mk1 5 speed
    Oct 2015
    Camden
    Mk1 5 speed
    Hey just a quick question
    How easy is it to fit a 5speed in a mk1
    Do I need different brackets
    Do I need different drive shafts
    Perth, WA
    Hi scoot13,
    Try using the search function on this forum it will bring up a lot posts on this subject, check out some peoples builds who have done this conversion before, you will find them pretty informative.
    93' MK1 cabriolet
    Aug 2006
    Melbourne VIC
    Box, shifter and mounts!
    Go down and talk to the guys at Camden GTI. They'll have lots of advice and the bits you'll need.
    Nov 2014
    Out of interest what is the going rate for box/shifter/mount ready to go on the second hand market
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Notso Swift View Post
    Box is easy enough to get since all Mk3 manual boxes are 020 (not vr6). Be aware that Mk3 020s have 100mm drive flanges so either new drive shafts are needed or the flanges changed to 90mm. Mk2 gti is a common source for the gearbox as well, complete with 90mm drive flanges.
    The linkage can be made by simply extending the shifting arm using a welder and some plate. The required pull rod can be bought new for pretty cheap too (vwheritage).
    The mount is the difficulty, because the only ones that work are out of a late model cabby or a gti. There is someone on here who modifies 4 speed mounts but I can't remember who...
    Easiest way is to keep an eye on the parts for sale section for someone selling the whole kit. They usually go for about 250-300 bucks
    Jul 2011
    Gldgti makes the mounts. Its posted in the stickies buddy
    Sent from my SM-G900I using Tapatalk
    Nov 2014
    Cool, I have a full kit sitting there as I am going 02j, one day will post it in the for sales but need to organise myself! (Probably no good for the OP as it is in Melbourne and it would cost $100 for freight)
    Oct 2015
    Camden
    Thanks for the help
    Will pop over to Camden gti and see them
    New to this forum stuff
    Will have a look
    Thanks
    Quote Originally Posted by Scoot13 View Post
    Noooooooooo
    Once you start talking to Matt you'll be looking at lower suspension, quicker motor, improved electrics, bigger brakes, steering mods, MK2 dash, brighter lights.
    And a 5 speed.
