Results 11 to 20 of 22
Thread: Mk1 4 Spd
    syncro Guest
    I thought they'd be getting a bit rare nowadays. All of the 5 speed boxes I've seen are out of Golf 2s.
    I tried to get a glove box lid for a '79-'80 GTI in England about 8 years ago and I couldn't get one.
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    i bought a mk1 with mk2 gti engine and box.. it is double the fun (and power) and that 5th gear is soo good on the highways about 2400 rpm doing 100 km/h
    do it if u can well worth it.
    jleahy_10 Guest
    I have to honest, and admit, with the mechanical side of cars, i am clueless. But i do have a 3rd year mechanic for holden who lives accross the road form me, is this a job he would be likely to be able to help me with or will i have to get it done at a trans place.
    Secondly, am i going to have to take the engine out, or will it be easier to take the engine out.
    Thirdly, me with a welder is a scary thought, so i would need a new mount yeah??
    Finally, it will be a couple of months before i do this, as i have spend my hard earned on other devices on the beast.
    Gosford Central Coast NSW
    Quote Originally Posted by syncro
    I should have said 1600 GTI. 1st is the same in the 4 and 5 speed and 4th is the same as 5th in the 5 speed. I doubt if you would get any of those boxes now.
    mollins has one in his 5 door 1800, and it is truely a hoot!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    you will need a new mount - loon can supply you with one.
    its easy to do the conversion in the car, and easy out. 2 guys can do it in half a day if you know what your doing, and you oughta be able to fluff through it in a whole day with a good manual and the right tools and some help.
    '99 A4 Quattro 1.8T
    oh , apart from the linkage crap, which is easy to do if you find a mate who can weld.
    '99 A4 Quattro 1.8T
    blackgti1.8 Guest
    That fifth gear is must have if you do highway cruising at all - The GTI is actually reasonably relaxed at 110 in fifth..
    More comfortable than than around town, come to think of it
    It pains me to think of all those kays I did with four speed box over the years
    Interesting Phill's comment about reverse - I have a feeling that it's reverse that plays up first when there an adjustment issue. One of these days I have to have another fiddle with my linkage - it keeps popping out...
    syncro Guest
    The 5 speed gearstick plate allows about 2mm more adjustment for reverse.
    Camden, Sydney
    Made from unobtanium in Australia these days, just grind down the 4 speed one for the same result.
    syncro Guest
    Quote Originally Posted by Golf Loon
    You must be dealing with one lazy dealer.
