Since you already have the 2.0 block measure the height from the sump (where it bolts to the block) to the top of the block. Now do the same thing with your existing motor. Is it the same? Good, no need for modifying the exhaust because it will sit in exactly the same space it currently occupies.
2.0 alternator will be more modern so run that one. It will be a better fit on the 2.0 block too.
You don't need another long shaft from the gearbox to the linkages.
Why aren't you using the 2.0 dizzy?
Why do you need a 2L Crank case blanking plate and freeze plug?
Have a look at your existing 1.8 block. The 2.0 is going to replace it so see what hangs off the 1.8 that the 2.0 needs to duplicate. If it's already a part of the 2.0 and can be connected to the existing wiring and plumbing then use the 2.0 stuff.
Don't forget, you won't get a big increase in horse power but the torque is much better and it's a great base for doing more work later (cam, hot head, EFI etc).
Paul
