both items are for US Spec engines, I have no doubt the engine would run on either metering unit but you would need to dyno it to check the air / fuel ratio across the complete rev range.
However here is the throttle body you need...
VW MK1 Audi 5000 big bore Throttle Body Rabbit GTI GOLF - eBay (item 320654872346 end time Mar-11-11 00:17:37 PST)
And the airflow meter is here.
VW MK1 CIS 80MM Air Flow Meter Rabbit GTI Porsche 924 - eBay (item 320654829039 end time Mar-10-11 20:17:21 PST)
and the cpr,
1976-1984 VW Bosch Warm Up Regulator 0438140011 GTI - eBay (item 220721576332 end time Mar-08-11 15:33:20 PST)
cheers,
Grant.
