Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Mk1 1.6 Performance upgrades
    Mar 2010
    Perth
    Perth. WA
    both items are for US Spec engines, I have no doubt the engine would run on either metering unit but you would need to dyno it to check the air / fuel ratio across the complete rev range.
    However here is the throttle body you need...
    VW MK1 Audi 5000 big bore Throttle Body Rabbit GTI GOLF - eBay (item 320654872346 end time Mar-11-11 00:17:37 PST)
    And the airflow meter is here.
    VW MK1 CIS 80MM Air Flow Meter Rabbit GTI Porsche 924 - eBay (item 320654829039 end time Mar-10-11 20:17:21 PST)
    and the cpr,
    1976-1984 VW Bosch Warm Up Regulator 0438140011 GTI - eBay (item 220721576332 end time Mar-08-11 15:33:20 PST)
    cheers,
    Grant.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jan 2021
    ... Some other things to consider..
    Get a Volvo 240 metering head and air flap.
    Audi throttle body
    Ported intake.
    These are also restriction points when working with Kjet.
    hi preen,
    which audi throttle body do you recommend and would you port the standard intake or is there a link to an aftermarket option?
    i currently have a 76 mk1 project and looking to keep the original engine just fix it up and maximise its output to a safe easy daily drive level.
    thanks,
    cam
    What engine do you have?
    Paul
    Nov 2022
    amesterdam
    some type of larger exhaust, a modified / better breathing camshaft, upgrade the throttle 192.168.100.1 192.168.1.1 body as preeny has said along with some de restricting of the inlet will give you some more power
