Results 1 to 10 of 18
Thread: Mk 1 rubbing sound on right hand turns
    Oct 2006
    Albany Creek Brisbane
    I noticed a rubbing sound today when turning the steering wheel to the right and turning corners
    No sound when straight or left hand turn
    Any ideas?
    Aug 2007
    Noise in what area?? near steering wheel or further down ?? Dry horn ring springs to mind.
    Alba European
    Jun 2006
    Orange NSW
    In the cabin or through the wheel?
    Could be a brake line that has come unclipped from the strut...
    Oct 2006
    It sounds like it is at the RHS front wheel
    I'll get under there today to see if I can see anything obvious
    Oct 2006
    Ps, what is and where is the horn ring?
    Jun 2006
    Orange NSW
    It's the copper contact ring on the back of the steering wheel (or steering wheel boss if your wheel is after market). It's what links your horn button to the rest of the car, because you can't have a cable on something that rotates..
    Sounds to me like you might have a knackered CV or your brake line is rubbing on your tyre line I said. Does it make a noise in reverse?
    Oct 2006
    I'll see if it does it in reverse, what do you lubricate the horn ring with as well?
    The noise is coming from the wheel
    Jun 2006
    Orange NSW
    Quote Originally Posted by Garbon View Post
    Wheel wheel or steering wheel?
    Jan 2010
    Melb Westsideeeee
    Could be your suspension or something like that dude, i used to noise jsut liek you descrive from the left front wheel, only when i turn right into corners. One day i took out my suspension and was playing around with it, and when i took it for a test drive, problem fixed.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Oct 2006
    Thanks for the replies, the noise is coming from the road wheel
