Honestly. I don't know all the ins and outs. BUt this is what I do know.
You should replace the head studs(/bolts) when you do a head gasket. There is a specific process involved with the way you tighten up the bolts when you put the head back on. (should be detailed in your haynes or similar manual)
The head it self should generally be skimmed before you put it back on. although you have a new head, so this mightn't be needed. The skim is to level out the head to get rid of any "warping" and deformation that has occoured to the head. This should be about $50 bucks at a machine/engineering shop.
Taking the off head doesn't seem hard, and really isn't. but there is a bit of work involved. If it's the first time you've done it, it'll take up most of an afternoon IMO.
Remove the timing belt cover and timing belt isn't difficult. Just make sure you put the head back on the same way as you took if off, just do it's easier to do the timing once the engine is back together.
You will need to remove the inlet and exhaust manifolds, which is a bit tricky, but defiantly do able. You might need replacement gaskets for these manifolds.
Removable of various bits of cooling hoses and thermostats etc.
Then pop off the cam cover/rocker cover, and you'll see the 10 head bolts that need to be taken out. They're torqued up fairly well, (or should be atleast) so it'll help to have a torque arm/pole handy to crack them.
That's just removing the head. I've done it a few times myself on some junker engines, so I'm getting pretty good at it. I just havn't put one back on yet! hahahha. so unfortunately that's where my advice stops.
I'm sure someone else will be able to pick up where I left off. I think you should be able to do it yourself though.
Off topic but; How did the wiper motor conversion go?
