Results 1 to 10 of 11
Thread: Mk 1 GLD clutch cable sloppy first 1 1/2 inches of travel
    Oct 2006
    Albany Creek Brisbane
    Hi All
    My GLD has always had a sloppy clutch pedal/ cable since i got it a few years ago. I have checked to make sure it has the correct diesel cable which it has.
    Why would the pedal be sloppy for the first 1 1/2 inches of travel before engaging the cable and clutch? Is there supposed to be a spring on the pedal to lift the pedal up or should the cable do all of the work?
    The cable is extended as far as it can go at the gearbox end. What else can I look for?
    Any ideas?
    Sep 2009
    Chillaxing in Tas
    every golf ive ever driven has been like this, i did fix it by putting it a hose clamp on the steering column acting like a "stop" for the pedal. Its only a quick fix though,
    Ive had a brand new cable and still had the slop..weird, ???
    <space for rent>
    Could be the wrong rubber block at the gearbox end. There's several different ones that I have come across in my time. Not sure how bad they got here but the cab;les used to pull through the firewall all the time in the UK. Check that's not flexing too.
    Oct 2006
    Thanks for the replies
    One of my GLD's is fine the other one is sloppy as described. I will look at the block at the gearbox end this weekend. I know that the rubber at the firewall is ok and has not pulled through etc. Have read about this on here too.
    Jan 2010
    Melb Westsideeeee
    Ive had the same problem in mine mate, i actually bought a brand new cable and have still had the same problem. I've been through 3 clutch cables and all the same thing haha :/
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Jun 2007
    Eastern Suburbs Melbourne
    I think that the slop is just due to wear and/or incorrect adjustment.
    I welded a nut to the pedal stop, to lower the action of the pedal from being way up high (where it's meant to be) to a bit lower down. That made it more comfortable to drive, imo.
    i like volkswagens
    Aug 2007
    Yeah the firewall pull through is very common and seen some elm st repairs, freddie kruger fitted it with a blindfold on, there used to be a repair kit you could buy back home not sure if its available here, sure Peter Jones would be able to answer that one. Rest of the wear will be in the box and the clutch itself, the plate the release rod rides on etc so without pulling it all apart i would probably space it out a bit at the gearbox cable mount hole where the cable goes through it. Just not too much that you have clutch slip
    Jmac
    Alba European
    Boronia VIC
    Fire wall plate via UK ebay.
    MK1 Golf GTi Cabriolet Bulkhead Clutch Repair Panel | eBay
    Just search for mk1 clutch repair.
    I reckon there's different blocks on the lever and different cables to suit.
    There needs to be the rubber buffer on the hole in the box as well as the big rubber block on the cable.
    Sometimes even that's not enough though.
    I make up a spacer to go between the lever arm and the clip that holds the end of the cable.
    Just a bit of 20mm x 20mm RHS about 40mm long with an 8mm hole drilled in will do. That's what I've got in the race car at the moment.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oct 2006
    Thanks for the replies and good ideas!
    Aug 2007
    Ah its still available, cool. And yep spacer for the win, knew you would chime in.
    Cheers mate
    Jmac
    Alba European
