All the repair sections came from the donor car. I cut the required areas from the donor, trim a bit closer then get them dipped clean.
The floor was trial fitted many times as we cut the lower bulkhead to incorporate the 4 bolt steering rack mounts from the 77 and later Mk1's as opposed to the earlier 3 bolt design. This was 2 pack primered before fitting into the body the last time.
You can make the repair sections yourself if you have the necessary skills. its not that difficult ( look at tech college adult ed classes )
Lots of MK 1 Scirocco's...
Cheers,
Grant...
