Ta-da!
Its the little things..
Got my speedometer cable custom fitted with the daihatsu end. It works but is about double what it should read.. Any body know of a fix..? Just not sure about the gears that go into the gearbox being interchangeable/universal as well.. Also got a daihatsu fuel gauge sender and replaced the mk1 one with it, first time welding so its all a little sketchy but works pretty accurately.
Dont judge my handywork! hahahaha
Coolant temp doesn't want to work for me at the moment either, will double check connections tomorrow. I will be putting in a aftermarket gauge for it later on anyway.
I really admire your work and the dash looks good!
Cheers dude, It's all coming together slowly. Our garage at home is usually full and i have to work outside/remove car cover etc everyday.. Not totally ideal, Would be awesome to just have a spot for it so i don't have to spend the half hour just packing up stuff before it gets dark. But what can you do![]()
Ughh anyone have a clue how i could replace the mk1 hazard switch with a generic one to fit my dash..?
I can get a 2 pol rocker switch to work fine, but when trying to use indicators they act as hazards also but when i put the factory hazard switch to the same 3 wires it seems to work normal?
So confused !
Other than that i have the headlights wired up to a new switch, highbeams and cluster lights working. Getting pretty over wiring already >:| At least all the dash stuff will be finished soon. As for my speedo problem, i talked with the guys who made my cable up and they said the only real fix is to fit a ratio box for around $140. I will probably get this done once its on the road and i can do the ratio/km test.
All dash wiring is complete, can be all fitted up now but priorities are set on the InterPro rust. Pulled off the guards and the holes were a little bigger than i thought..
Here is a picture the pile of crap that fell out when the drivers guard came off haha
Anyone know someone South Brisbane mobile rust quotes as i don't really want to take the car to a shop just for a quote. The inner wheel well (Inside the cabin) on both sides need replacing. Would do myself but i dont know how to go about getting the whole curved thing happening hah
For the hazard switch get a on/off rocker that has 2 separate circuits and wire one for each side of the car. That way you aren't joining the left and right side together in a single circuit that will let the normal indicator switch feed back into the rocker switch to turn on both sides of the car at the same time.
