Results 11 to 20 of 25
Thread: Mark 1 TURBO
    Mar 2007
    South Brisbane
    I think more info or even pictures of the engine bay will help as stated above, is it a blow though carby setup??? or electronic/K-jet injection???, only reason im asking ive seen more blow though cabry setups on mk1s than injection
    Apr 2010
    brisbane qld
    Its blow through and how do i upload pics?
    Feb 2010
    Perth
    Look at Gaz' from CVWC.
    I will try to find the pics...
    77' MkI Golf GLS - VR6-T Project Compression
    79' MkI Golf GLS - 2L ABF ITB's Wolf3D
    09' MkV Golf R32 - sold
    Feb 2010
    Perth
    Heres...
    Jan 2009
    south west sydney
    What about some sort of factory cooler from an s13 or something. Theyre small and thin and you could pick one up for like $20. Would be better than nothing. I'd love to see some more detailed pics and some more info on your setup.
    Jun 2006
    Orange NSW
    Everything you could want to know can be found here: • View topic - 76er Phase 2 Turbo build
    I've driven it. It rocks.
    Jan 2009
    blankedy
    If you are worried about space in front, maybe a side mount? A fair few Polo GTI guys have them sitting around (I do...) so it would be cheap and drop your intake temps by a few deg. They hold up to the 20ish PSI a chipped 1.8T kicks out, but they will heatsoak in summer with that much boost.
    Gosford Central Coast NSW
    you can fit a 2.5" thick core in front of the radiator without cutting anything really, just elongate the holes in the radiator bottom mounts a tiny bit for an extra 5mm. a 600mm wide core will fit right across the front like the pic posted just earlier, and with a stock engine bay you can have the piping come out from under the battery tray on the passenger side. the intercooler cant be more than about 240mm tall because of the bonnet catch, unless you don't have a bonnet catch and are using pins instead.
    we did this on the mk1 TDI we built.... worked fantastically well. also only took about half a day to mount the intercooler and plumb it all in, but then I am pretty awesome
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2007
    South Brisbane
    When you post reply in advance there is a option to upload pictures
    Jan 2009
    south west sydney
    that's his setup. You'll introduce a bit of lag with the amount of extra piping you would need.
