Im running 8psi and dynoed at 155hp !
plenty of room for a front mount just have to run pipes down either side of the engine, lag shouldn't be a problem depend on the size of the turbo which im guessing isn't huge anyways, how much boost you running? and dyno figures??
Not bad on 8 pounds.![]()
Thats the one that was for sale a couple of times yeah?
Do you have pics of the whole set up. I remember it only being a turbo manifold, turbo and fuel pressure reg. Its cant be that simple can it? If it is, i want to give it a go!
How do the box and internals handle the boost? Is there much slip.
MK1 GLS 3door
A4 B7 2.0T
I have custom made 4 into 1 steampipe manifold, vr4 highflowed turbo, 2.5 inch exhaust, blow through webber carby, repco thumper primer fuel pump feeds a vl turbo fuel fump which goes through a malpassi 1.7 to 1 fuel reg, freshly rebuilt engine, 1.6l, mahle pistons and rings on standard rods with arp bolts,210mm bras button clutch not to mention last week i spent $1000 on getting the head ported polished decompressed and a new headgasket. Thats what has been done to mine but im sure you can get out of i cheaper if you wanted too ... my headgasket itself was $400 but they had another one i could use that was $140 same thickness.... im sure you could do it all for half what mine cost !!
