Results 1 to 6 of 6
Thread: Manifold compatibility 1588cc Engine Mk4 manifold?
    May 2018
    Sunshine Victoria
    Hey Guys,
    Does anyone know whether a manifold off an ADY or similar 2.0l motor will bolt up to a 1588cc Mk1 cylinder head?
    Cheers,
    Gregdub
    Aug 2006
    Melbourne VIC
    Inlet or exhaust mate?
    May 2018
    Sunshine Victoria
    My brain.... Inlet specifically, although now that you ask, exhaust too?
    Aug 2006
    Melbourne VIC
    Counter flow is different pattern to cross flow.
    So to answer your question no it will not fit.
    May 2018
    Sunshine Victoria
    What about the u-flow motors only. Any difference between the 1600 and the 2.0 litres?
    Perth. WA
    No, ports are different shape as the injectors are now located in the manifold. The port looks like an inverted T as opposed to the 1600/1800 kjet / carb cars with the oval ports.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
