Results 1 to 4 of 4
Thread: machining mk1 100mm axels to fit 90mm carriers
    Mar 2014
    hollybank, tas
    I have heard of a guy machining 100mm axels to fit 90mm hub carriers can this actually be done ???
    PHP Code:
    mi
    2001 black gti 18" tt rims ,kmacs and a big dent (daily until rego runs out and mk1 is painted )
    76 gls 3dr agu ( build in progress, )
    77 gl parts car
    Feb 2013
    sydney
    you can get flange kits to suit 90mm axles ]
    the flange is for the gearbox side
    Mar 2014
    hollybank, tas
    Cheers I have a 02m in my mk1 and would like to upgrade the axel size for strentgh thanks for your help anyway
    PHP Code:
    mi
    77 gl parts car
    Feb 2006
    Melborune, VIC
    It can be done. When you see the interference points you can just machine down that section and make sure you radius any steps that are created. However, if your car is on 15mm balljoints, you may want to change to later uprights to allow 17mm balljoints and extenders to be used, if you go low.
