Results 1 to 8 of 8
Thread: Lynx M150 Manifold / Weber DCOE Jetting?
    May 2018
    Sunshine Victoria
    Hi All,
    I'm hoping someone has information on the best DCOE and jetting to use with an M150 manifold?
    I'm running a 1600 Mk1 motor, mild cam, extractors and a 2 1/4 inch exhaust.
    I've got a DCOE 40, I think with 28 chokes.
    Previously (22 years ago) I ran a 45DCOE, but I don't recall the choke size.
    Google is surprisingly silent on the issue of the best arrangement, so hopefully someone has some knowledge of the topic?
    I'm not averse to ditching the 40 for a 45, or enlarging the chokes on the 40; I'm just hoping to get to a reasonable starting point to begin the tune.
    Cheers,
    Gregdub
    Aug 2006
    Melbourne VIC
    I know Nigel at The Carby shop in Knox should be able to point you in the right direction.
    Jun 2006
    Orange NSW
    Your 28mm chokes will limit your power output greatly with your setup i would swap them for 34mm chokes as a starting point and jet them accordingly. No need to go to the 45mm DCOE unless your planning on a lot more modifications.
    I jetted a 1.8 with the same manifold and 40 DCOE a long time ago and although i cant remember the jet sizes i do recall the inlet manifold runner for #4 cylinder was a lot longer and as such had a larger volume than the others. Because #1 and #4 cylinders feed from the same throat to enable #4 cylinder not to run lean the jet sizes were increased causing #1 cylinder to run a little rich causing the spark plug to foul. Twin 40mm DCOE are a great option. Cheers Marty
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    May 2018
    Sunshine Victoria
    Quote Originally Posted by Water Boy View Post
    Cheers Water Chap!
    May 2018
    Sunshine Victoria
    Bang on regarding the 1-4 intake lengths Marty! I'd hunt down a double manifold, except I've got my heart set on straight LPG with a BLOS propane carb and SLK blower setup as the final aim. The DCOE is a stepping stone, because the single stock carb is pretty uninspiring... Thanks for the tip re the chokes. I'll open the carb up and see if I reckon I can open them up on a mill. If not, ebay I guess.
    Jun 2006
    Orange NSW
    Sounds like a interesting setup you have in mind with the LPG and blower. Be sure to post up some pics.
    I have machined out chokes before and your best option is on the lathe because they are actually tapered through the bore, I cant remember the angle of the taper but that is easily measured. The taper is critical to create a suction through the venturi.
    Audi A4 B5 1.8t
    May 2018
    Sunshine Victoria
    The answer for the Lynx M150 (as a starting point) seems to be:
    But as a starting point with 40DCOE
    34mm chokes
    160 mains
    F16 emulsion tubes
    180 -200 air correctors
    65F8 idles
    50 pump jets
    May 2018
    Sunshine Victoria
    Lynx M150 Manifold / Weber DCOE Jetting?-img_20181010_134513-jpg
    As an addendum, I bought some new chokeson the ebay from "carb deals". They're aftermarket, cheaper than the original items, and polished! Quality appears to be much nicer than the genuine item...
