Hottuning with the rear spring cut in half
What are the lowest coilovers out there for a mk1?
Specifically in the rear in comparison to kw,hr, bilstein etc?
Are they all the same?
2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
Radiators are over rated
probably the H&R ultra ultra low, how ever I do believe theses are non existant new these days.
Have you considered drop plates?
PSI sell them new - probably other companies do too, but they aren't exactly cheap - H&R Ultra Low Coilover Kit - Golf I+Cabrio/ Typ 17, 155, Spezial Rebound 50 mm, 79> > Suspension > Golf Mk1 1974-1983 > VW Golf > VAG Specialists > PSI Tuning - VW Specialists
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Coilovers + strut top raisers + tie rod flip kit + notch + rear drop plates = lowest!
Pretty much exactly what Woody said above!
You'll be needing to notch both driveshafts if you plan on being super super low though..
thanks guys i dont want to mess with driveshafts and drop plates etc.
Someone mentioned FK Highsports are the lowest at the rear that dont cost a bomb?
I had some weitec's they did well for lows. Though the combination with 13" phats probably made most difference.
I did have to have the chassis notched also
