thanks for that ray, filled in a few gaps..
I'm curious to see a shot of under the rear between the spring and wheel. it must be might tight under there!
mk1-2-3-4 all have factory negative camber on the back that is built into the rear beam.
You always notice with wider wheels because literally, its a lot easier to see the wheel from infront or behind when they stick out of the car further. Stockies you cant see so well or at all and you cant see the camber so much when you are at more oblique angles.
Not sure exactle what camber is stock on the mk2 and 3, but its between 0.5 and 1 degree negative.
IF you have very badly worn or badly adjusted rear wheel bearings, you might get some more negative camber.... but that idea scares me![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
wheels are from nissan skyline r33 16x8.5 et33 with 3.5" lip. at the moment there are on the car with no spacers and clearing the coilover spring about 10-15mm. no bend stuff on the car or crashed bearing or so on.my gues is that the car is low and the bastard is wide and show more negative camber. i would say nothing too extreme![]()
no adaptors multistud original 4x100/4x114.3
ahh cool, i thought r33's came out 5x114.3..............
dom
i think non turbo models and 4door come in 4x114.3.....
