Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: Lowering my mk1
  1. #31
    Nov 2005
    Quote Originally Posted by rayray086 View Post
    I've seen Mick's (dado) car in the flesh, and the rear is low, tucking 1/3 of the sidewall if looking side-on. They are definitely 8.5" but at ET30-something. The camber is quite negative though (looks more than -2 to my eyes...), which is why it's just flush. Not running any camber shims. Is there a difference if he's running drums at the back (compared to discs)? Or is it the same track between the two?
    His fronts are 7.5" ET33 I think he said, same tyres, but currently not tucking tyre as any lower and the perches will catch on the tyres. The inner rim is almost touching the strut body, so you can imagine how close his setup is at the moment. Also some mad camber there (not as much as rears though). He wants to go lower (reverse raking right now) but can't until the fronts are using spacers (at least 15mm to clear the spring perches as they're about to catch on the top of the sidewall). I told him about your strut tower spacers, and I think helpers can be taken out (they're JOMs) to get lower without winding the spring perch down. Maybe not a combination of the two, but one or the other should be enough to get him where he wants.
    thats all awesome stuff to know, but you cant have rear camber without shims of some sort, the rear of a mk1 already as a slight camber angle of 0.5deg though disc or drums are the same thing
    dom
  2. #32
    Jun 2007
    Eastern Suburbs Melbourne
    thanks for that ray, filled in a few gaps..
    I'm curious to see a shot of under the rear between the spring and wheel. it must be might tight under there!
    i like volkswagens
  3. #33
    Sep 2006
    West Sydney
    Quote Originally Posted by WABIT View Post
    My thoughts too but even on my Mk3 it's showing close to -2. Perhaps something's bent/worn which might cause this?
  4. #34
    Aug 2006
    Melbourne VIC
    Funny u say that Jarred and myself noticed that mt Mk3 has some camber on the back and is more noticable with the 7's on the back. (Nothing crazy though)
  5. #35
    Gosford Central Coast NSW
    mk1-2-3-4 all have factory negative camber on the back that is built into the rear beam.
    You always notice with wider wheels because literally, its a lot easier to see the wheel from infront or behind when they stick out of the car further. Stockies you cant see so well or at all and you cant see the camber so much when you are at more oblique angles.
    Not sure exactle what camber is stock on the mk2 and 3, but its between 0.5 and 1 degree negative.
    IF you have very badly worn or badly adjusted rear wheel bearings, you might get some more negative camber.... but that idea scares me
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  6. #36
    wheels are from nissan skyline r33 16x8.5 et33 with 3.5" lip. at the moment there are on the car with no spacers and clearing the coilover spring about 10-15mm. no bend stuff on the car or crashed bearing or so on.my gues is that the car is low and the bastard is wide and show more negative camber. i would say nothing too extreme
  7. #37
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by dado View Post
    What adaptors u running?
  8. #38
    no adaptors multistud original 4x100/4x114.3
  9. #39
    Nov 2005
    ahh cool, i thought r33's came out 5x114.3..............
    dom
  10. #40
    i think non turbo models and 4door come in 4x114.3.....
