Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Lower Ball Joint Extension's
    Mar 2009
    Empire Bay NSW
    Here's a link to an old thread i found just wondering if anyone is running these? and if so were to you purchase them from......Looks like the only way to get a mach 1 slammed while maintaining almost stock suspension angle for you lower control arm.Would make for an awesome ride combined with strutt spacers/and flipped tie rod ends up front
    http://www.vwwatercooled.org.au/newf...int+extensions
    Jan 2006
    Hi there,
    I am running these, I actually have Valvers old set. I flipped the tie rods in conjunction and everything is level. Mind you my car isn't ridiculously slammed or anything. I did change a few things at the same time as this such as a 4 point lower brace, and larger sway bars, so its impossible to isolate the handling difference from just the extenders, but the car is definitely sharper, more stable and less bumpsteer.
    Mar 2009
    Empire Bay NSW
    found them not cheap though (a good thing considering its your front end)
    www.PMWltd.com .....here's some pics of their work looks like quality stuff
    and their double A arm set up
    these guys also do the flip kit for tie rod ends for anyone intereseted
    These will also work made for Aircooled beetles and are 20 bucks cheaper
    http://www2.cip1.com/ProductDetails....12%2D6613%2D11
    Nov 2005
    ask jarred, hell know
    dom
    sydney
    im halfway through getting some machined from 4140
    they are longer than the pmw ones as my car will be super low and has enough room in the wheel to accommodate a little more drop/seperation
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Mar 2009
    Empire Bay NSW
    They look good Alex how much are you extending by?........i really need to get off the computer just found these 2'' drop plates for the rear look nice and easy to make too this combined with 2'' balljoint extensions would make for an almost stock quality ride 4'' drop would be easily obtained combined with coils and front strutt spacer
    Might get some of these drop plates laser cut if anyone is interested ...
    sydney
    my extenders are a full 50mm of raise
    i will be doing a run of drop plates for a few people soon, remember that the wheel is still going to have full travel when using drop plates so serious tyre scrubbage can become an issue
    Mar 2009
    Empire Bay NSW
    Read your pm first al keep us posted on the drop plates
    Jun 2006
    Orange NSW
    Quote Originally Posted by alex g View Post
    You could run an extra bump stop to alleviate this..
    Jul 2005
    Newcastle, NSW
    I reckon alex would call you soft if you did that Preeny... Scrubbing is like religion to him.
