Originally Posted by
golfworx
You also have to get the right valves with the right number stamped on them too. #15 I think
15 is for discs
35? is for drums.
They are completely different & if you use the ones for drums on disc's you'll end up with lock up's. Just like I did, as it allows too much fluid to pass through to the rear calipers!
Just found a pic of them! # 15 is was!
the 15 and 35 refer to the cut off pressure the valve is set at, lower pressure one for discs, higher one for drums. The valves are identical internally except for the preload spring. When time permits I will investigate the cost of having springs wound to convert the drum valves to disc valves.
# for Disc brake valves is 533 612 151 A, and for Drum brake valves is 533 612 151 . neither types of valves have the part numbers on them, only the pressure rating numbers as Tim has said. Beware of buying them of vortex etc as they will sell you the drum ones instead of the disc ones...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
