WOW Byron.
Cabby's are great cruisers for the summer bud
Check the rear side window seals, they want to be in very good condition. If the seal against the glass is poor ( cabby rear quarter windows roll up and down same as the door glass ) then rainwater can enter the inner sill area causing rust way down the bottom. Windscreen frame where the glass sits and at the point where the front guard meets the base of the windscreen can be a rust spot as mentioned above.
The aussie delivered later cars are pretty gutless ( JH on Kjet ) but updating to a 2E short block and a few other minor upgrades can make it get up and go.
Pics when you go check it out please. Good luck.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
