Should be the same. Just need to cut it shorter I assume
^^ does this apply to 4 door mk1's??
Great tip, thanks.
Just don't do it in the middle of winter - would take ages for the rubber to adjust to it's new shape.
It's time I let you in on a secret of mine. My little bunny is getting a new heart some time in the next couple of months. I stumbled upon a crossflow, external water pump block know as an AFT out of a 99 Cordoba late last year, and have slowly been putting parts together to get this thing ready. I'm almost ready for the big day, so I thought you should all informed of the journey so far.A little dirty. Time for a bath
And a home botch port job
Partner her with a 280 hydro Cat Cam, and some Autotech HD valve springs
Add on a Rowland manifold (home painted)
Extractors
Just time to sort out the pair of Dellorto DHLA 40s going on it.
Still have to organize distributor and associated ignition, alternator to fit under the carbs, offset radiator and a couple of other bits and bobs before the conversion can go ahead.
This is an exciting time for my bunny...
So it will look like this when it's finished?
Taken from here in case you haven't seen this one.
http://www.clubgti.com/showthread.ph...45-carbs/page5
Yours will be something special when it's done!
Paul
Nice engine! I'd be stoked if it looked like that. Here is my main sources of inspiration though...
Cheeky little mock up today with the freshly painted block![]()
Does all the water and oil galleries line up from the head to block?
What head gasket you going to use?
Geeez! Loving how different this is! Wasn't aware of any crossflow 8v engines.
What's the displacement?
It's a 1.6 with the 81mm bore that all the 1.8s came with. So it's very simple to stroke out. I'm leaving it as a 1.6 however, due to short stroke, it will love to rev
It's a factory head for the block. No modification required. It's a shame how rare they are in Australia, but it does give me some ner ner value haha
