Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 107
Thread: A little pickle
  1. #81
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Petska84 View Post
    Very nice Jordan, just a little tip the coil and yes it does look awesome how it's positioned ATM but it will perform at its best when not heat soaked. Sorry dude just my 2c worth.
    I thought this was the case. It's most likely only going to be a temporary position until I get the whole engine bay sorted. Never the less, my exhaust will be wrapped and the coil will get plenty of airflow being positioned on top of the valve cover, so I'll wait and see and move if need be
  2. #82
    Nov 2009
    Coils don't like vibration either
  3. #83
    Aug 2006
    Melbourne VIC
    Well done mate. Looks amazing!
  4. #84
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Vinda76 View Post
    Looks like I'm moving it then
  5. #85
    Nov 2009
    Great work mate, looks fantastic and very interested how the performance turns iut
    gav
  6. #86
    Looks great, can't wait to hear how it goes.
  7. #87
    Jan 2010
    Melb Westsideeeee
    Oh wow, that's looks awesome. Really neat setup. How hard was it to get the whole cross flow head on?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  8. #88
    Feb 2013
    Melbourne SE
    Quote Originally Posted by GeorgeMK1 View Post
    The head was matched to the block from factory. No modification needed. AFT engines came with a crossflow head on an external water pump block, so they are piss easy to put in a mk1. No mess with mounts or exhaust manifolds or anything of the sort, just the intake is different
  9. #89
    Nov 2014
    Looks great!
    Quote Originally Posted by Browneye View Post
    Serpentine belt conversion (thanks dado for the required bits). Running a slightly larger alternator pulley from a mk4 to help keep them revs upA little pickle
    That smooth wheel/pulley/tensioner should not be running on the inside of the belt (ribbed side)
    You can buy belts in 5mm steps so I would find the right one
  10. #90
    Feb 2013
    Melbourne SE
    The smooth pulley is the water pump and needs to spin clockwise. This is the way vw did it from the factory (who knows why) and I was a little confused myself
