Results 1 to 10 of 13
Thread: lightened flywheel ?? clutch advise??
    May 2006
    Maryborough Vic
    Question lightened flywheel ?? clutch advise??
    should i lighten my flywheel motor is fairly worked
    as is in other thread
    but is there much to be gained by taking a third
    or quarter off the weight
    and where is the best place to get a 200 mm clutch kit
    from and is there more than one type in that size
    already ordered wrong one once thought it was a 210mm
    they might not be so nice if i order the wrong one again
    thanks
    Aug 2006
    Upper Ferntree Gully Victoria
    Depends on wether you want torque or acceleration a lightened flywheel will pickup rpm quicker but because the rotating mass will be less therefore less stored energy ergo less tourque we pulled a heap of weight from the flywheel of another car we own and revs out much better but you use the gearbox much more with a car already modified to rev harder I would simply clean up the flywheel and get it balanced
    Cheers T
    MK1 RALLY CAR
    SUPERCHARGED MAZDA323 AUTOCROSS CAR
    Camden, Sydney
    Quote Originally Posted by ontarv
    thanks
    1.6 is 190mm GTI Is 210mm
    I think 200 must be a Diesel
    There was a new clutch kit for 200mm on Ebay recently, check the completed listings.
    I`d change the flywheel and put the common 210mm clutch on it
    Gosford Central Coast NSW
    diesel is 190 also...
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    I reckon the 210 is 1800 GTI. The 200 I think is 1600 GTI and 190 for everything else. Could of course be talking rubbish!!
    Jul 2005
    clutch
    200mm is 1500 dsl in Australia.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    May 2006
    Maryborough Vic
    Talking
    thanks for the advice
    my old clutch was 180mm by the tape
    and ended up rather purple, flywheel as well
    makes sence that it would be a diesel flywheel
    its has a lot weight to it than the old one
    not long brought this flywheel was ment to be 210 mm
    but i'll as long as it holds a bit better than old clutch
    i'll be happy and also funds are short
    was thinking of balancing as well, as old one was
    so i will lighten it i bit and balance
    thanks guy's
    Camden, Sydney
    Buy This
    http://cgi.ebay.com.au/Vw-Volkswagen...QQcmdZViewItem
    He also has the pressure plate in another auction
    May 2006
    Maryborough Vic
    Talking
    thanks loon your a legend!!!
    just messaged him to see if pressure plate
    had center and clip
    cause it wouldn't be the same as smaller clutch
    would it??
    Mar 2006
    WA
    A mate of mine took the standard flywheel, had it turned out to a larger diameter (i think 200mm) and threw the big clutch in it, you lose your little alignment nobs, but you get a light flywheel and a big clutch cheap cheap.
    76' Mk1 Rally Car, 1800 8v haltech ecu
    94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
    89' EA ex taxi, lpg, cheap and easy
Similar Threads
  1. HELP! Clutch pedal stuck all the way in...
    By gman in forum Mk3 Golf & Vento
    Last Post: 24-01-2007, 07:33 AM
  2. CLutch Pedal - Hydro
    By golf3 in forum Mk3 Golf & Vento
    Last Post: 30-06-2006, 07:47 AM
  3. need advice on upgrading to a bigger clutch
    By mollins in forum Mk1 Golf
    Last Post: 09-01-2006, 07:56 AM
  4. Which clutch
    By Gas in forum Mk1 Golf
    Last Post: 03-08-2005, 05:50 PM
  5. Lightened Flywheel
    By Golf Loon in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 07-07-2005, 07:43 PM
