Results 1 to 8 of 8
Thread: Lifter Noise, Fixes
    Sep 2009
    Chillaxing in Tas
    Lifter Noise, Fixes
    Got some pretty nasty Lifter noise in the 1.8L, pretty sure they are the hydraulic ones.
    They only go off when engine is warm, and from my reading on google, Lifter noise when warm/hot and not when cold means a shagged lifter or two.
    Any suggestions on what to do next, is it possible to pull current ones out and clean/scrub ect and put back in, or is it not worth the hassle?
    <space for rent>
    Feb 2007
    It about $80 for 8 brand new lifters from GAP.
    Me, on my mk1 and mk2, and my mate on his mk2 have tried everything from thicker grades of oil to thous additives, but once there ****ed there ****ed.
    You can take them out and attempted to open them up and clean the gunk out (as ive seen on vortex) but it doesn't always work and is very short term if it does.
    I'd say just replace em, there not expensive and doesn't look to hard to do with the right tools.
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2009
    Chillaxing in Tas
    dont worry, just found this link
    FAQ - reconditioning your tappets..... - Club GTI
    <space for rent>
    Mar 2009
    ahah i have the same issue in my 1.8, after track day they carry on like no end and it sounds like the engine is falling to bits...but once they cool down it's no problem...i bought 8 new ones for $100 but haven't put them in yet.
    78 2-door 1.8 KR 16v - twin dellorto's
    Sep 2009
    Chillaxing in Tas
    where did you get them? local?
    Ive just pulled all mine out, 2 are seized shut !!!!
    <space for rent>
    Jun 2007
    Eastern Suburbs Melbourne
    I've heard running .5L of diesel in with the oil before a change (just as you would an oil flush/additive thingy) can solve that.
    the diesel works by breaking down all the sludge, which helps you run out the crap, which means the lifters get full oil like they're meant to and stop being noisey
    My old audi was terrible with it, and afaik it was solved using this method. (after I had sold it..)
    i like volkswagens
    New lifters won't help lots if the oil pump strainer is blocked with muck. Drop the sump off as well and give it a clean out.
    Sep 2009
    Chillaxing in Tas
    Thats the Plan, need to organise a new sump gasket first.
    Going to soak the Lifters in diesel for a few days.
    May have a replacement set coming this weekend, so all good.
    <space for rent>
