Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Leaking heater matrix anyone blanked it out
    Perth. WA
    Quote Originally Posted by syncro
    Golf 2s have a full flow heater and the coolant goes back up through the head. Golf 1 has a tap to turn the heater on and off as it bypasses through the manifold or on a K-Jetronic there is a small U shaped hose that allows some of the coolant to flow when the heater is off.
    Does that make sense?
    (I don't know about later models)
    Thanks syncro, yep , familiar with the Mk1 set up, just didnt know about the Mk2 set up.
    One thing with the Kjet Mk1 u shaped hose, it has a restrictor in it for those that didnt know ( steel plug with a hole drilled in it ) ...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    syncro Guest
    Quote Originally Posted by roccodingo
    That's so the heater works...
    sydney
    all sorted thanks lads
    the digi motor is a bastard so many extra senders and crap, just put a u section in line but there was one way valves on each hose near the bulkhead and under the coil and intertwinned with the earth strap so it was a back breaker
    seens good
    now need a few oil changes to get the ratle out
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
Similar Threads
  1. Heater Matrix
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 18-03-2007, 09:35 PM
  2. Heater Repair
    By moto in forum Mk2 Golf & Jetta
    Last Post: 29-01-2007, 01:06 AM
  3. Heater Matrix replacement
    By h100vw in forum The Audi Quarter
    Last Post: 08-12-2006, 08:27 PM
  4. leaking heater matrix
    By alex g in forum Mk2 Golf & Jetta
    Last Post: 22-11-2005, 05:48 PM
  5. 100/200/V8 heater matrix
    By V8quattro in forum The Audi Quarter
    Last Post: 04-10-2005, 05:38 AM
