I see lots of Mk1s with it bypassing the heater. No reason you cant, but it is winter soon.
did it on the mk1 a few weeks ago and have just relised that the mint alpine mk2 digi is filling the passengers footwell with coolant. i need to block it asap, is there any reason a u section cant be fabbed to return the water before the bulkhead.
any experience
thanks lads
yer but dumping 4 litres of coolant in two days into my interior aint that good, i think i will put up with the cold mornings![]()
New Heater Matrix?
Or a secondhand one from my shed?
On an injected Golf, make sure that you do not blank it off!
You must make a U hose.
May I ask why and which model golf thanks syncro ??Originally Posted by syncro
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Golf 2s have a full flow heater and the coolant goes back up through the head. Golf 1 has a tap to turn the heater on and off as it bypasses through the manifold or on a K-Jetronic there is a small U shaped hose that allows some of the coolant to flow when the heater is off.
Does that make sense?
(I don't know about later models)
i found that camira's run a coolant hose with a 180 degree bend in it and if you cut it to length it fits mint and will ensure coolant flow to your head without it pissing on your floor![]()
77 Golf tarmac rally
89 porsche 911
80 Rabbit 4dr
11 mk1 and 2\'s in various states of undress
KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
I remember buying the GTI hose before which is about 75mm long and had to mortgage the house to by it.
I reckon al can fab something!
