Results 1 to 10 of 13
Thread: Leaking heater matrix anyone blanked it out
    sydney
    did it on the mk1 a few weeks ago and have just relised that the mint alpine mk2 digi is filling the passengers footwell with coolant. i need to block it asap, is there any reason a u section cant be fabbed to return the water before the bulkhead.
    any experience
    thanks lads
    Camden, Sydney
    I see lots of Mk1s with it bypassing the heater. No reason you cant, but it is winter soon.
    sydney
    yer but dumping 4 litres of coolant in two days into my interior aint that good, i think i will put up with the cold mornings
    Camden, Sydney
    New Heater Matrix?
    Or a secondhand one from my shed?
    syncro Guest
    On an injected Golf, make sure that you do not blank it off!
    You must make a U hose.
    Perth. WA
    Quote Originally Posted by syncro
    May I ask why and which model golf thanks syncro ??
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    syncro Guest
    Golf 2s have a full flow heater and the coolant goes back up through the head. Golf 1 has a tap to turn the heater on and off as it bypasses through the manifold or on a K-Jetronic there is a small U shaped hose that allows some of the coolant to flow when the heater is off.
    Does that make sense?
    (I don't know about later models)
    Feb 2006
    Perth Western Australia
    leaky heater
    i found that camira's run a coolant hose with a 180 degree bend in it and if you cut it to length it fits mint and will ensure coolant flow to your head without it pissing on your floor
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    syncro Guest
    I remember buying the GTI hose before which is about 75mm long and had to mortgage the house to by it.
    Camden, Sydney
    I reckon al can fab something!
Similar Threads
  1. Heater Matrix
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 18-03-2007, 09:35 PM
  2. Heater Repair
    By moto in forum Mk2 Golf & Jetta
    Last Post: 29-01-2007, 01:06 AM
  3. Heater Matrix replacement
    By h100vw in forum The Audi Quarter
    Last Post: 08-12-2006, 08:27 PM
  4. leaking heater matrix
    By alex g in forum Mk2 Golf & Jetta
    Last Post: 22-11-2005, 05:48 PM
  5. 100/200/V8 heater matrix
    By V8quattro in forum The Audi Quarter
    Last Post: 04-10-2005, 05:38 AM
