I see lots of Mk1s with it bypassing the heater. No reason you cant, but it is winter soon.
did it on the mk1 a few weeks ago and have just relised that the mint alpine mk2 digi is filling the passengers footwell with coolant. i need to block it asap, is there any reason a u section cant be fabbed to return the water before the bulkhead.
any experience
thanks lads
yer but dumping 4 litres of coolant in two days into my interior aint that good, i think i will put up with the cold mornings
New Heater Matrix?
Or a secondhand one from my shed?
On an injected Golf, make sure that you do not blank it off!
You must make a U hose.
May I ask why and which model golf thanks syncro ??Originally Posted by syncro
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Golf 2s have a full flow heater and the coolant goes back up through the head. Golf 1 has a tap to turn the heater on and off as it bypasses through the manifold or on a K-Jetronic there is a small U shaped hose that allows some of the coolant to flow when the heater is off.
Does that make sense?
(I don't know about later models)
i found that camira's run a coolant hose with a 180 degree bend in it and if you cut it to length it fits mint and will ensure coolant flow to your head without it pissing on your floor
77 Golf tarmac rally
89 porsche 911
80 Rabbit 4dr
11 mk1 and 2\'s in various states of undress
KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
I remember buying the GTI hose before which is about 75mm long and had to mortgage the house to by it.
I reckon al can fab something!
