That's so the heater works...Originally Posted by roccodingo
Thanks syncro, yep , familiar with the Mk1 set up, just didnt know about the Mk2 set up.Originally Posted by syncro
One thing with the Kjet Mk1 u shaped hose, it has a restrictor in it for those that didnt know ( steel plug with a hole drilled in it ) ...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
all sorted thanks lads
the digi motor is a bastard so many extra senders and crap, just put a u section in line but there was one way valves on each hose near the bulkhead and under the coil and intertwinned with the earth strap so it was a back breaker
seens good
now need a few oil changes to get the ratle out
