Results 1 to 7 of 7
Thread: Larger Mk 1 Fuel tank
    Sep 2008
    Bentleigh East Victoria
    Hi all
    Does anybody know if there are other fuel tanks with a greater capacity than the standard 45 litres which is fitted to a 77 carby engined car that can be fitted. I'm not to concerned if the fuel pick up outlet is in a different spot.
    Geoff
    Nov 2005
    mk1 cabriolets have bigger tanks
    dom
    Perth. WA
    Quote Originally Posted by WABIT View Post
    dom
    Hi Geoff,
    As Dom has said, the latter Cabriolets had larger fuel tanks, However they wont fit straight into an earlier car unless you remove some of the underfloor bracing that goes across the car behind the original tank.
    HTH,
    Grant.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2008
    Thanks for that info DOM and for the extra detail GRANT. It steers me in the right direction. We're looking at doing a long distance event in the rally car next year and looking for as much tank capacity as possible.
    Geoff
    Nov 2007
    St. Paul, MN
    more fuel?
    Look around I have seen a couple of tire well tanks on ebay the last year or so gives you another 5gal or so I think
    Dec 2007
    Somewhere in Melbourne, Victoria
    Quote Originally Posted by mnaussie View Post
    Are these legal? I thought they would need to be under the floorpan.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Sep 2008
    Certainly any fuel tank must be totally sealed from the passenger compartment in a CAMS approved motorsrort car. I'm not saying that it's impossible but it's not easy. There is a SD1 Rover V8 rally car which is a big hatch back which runs an alloy tank in the back and it has some sort of high tech perspex panel which seals it from the passenger compartment. I am going to lot into the cabriolet option and maybe a 5 speed box.
    Geoff
