mk1 cabriolets have bigger tanks
dom
Hi all
Does anybody know if there are other fuel tanks with a greater capacity than the standard 45 litres which is fitted to a 77 carby engined car that can be fitted. I'm not to concerned if the fuel pick up outlet is in a different spot.
Geoff
dom
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Thanks for that info DOM and for the extra detail GRANT. It steers me in the right direction. We're looking at doing a long distance event in the rally car next year and looking for as much tank capacity as possible.
Geoff
Look around I have seen a couple of tire well tanks on ebay the last year or so gives you another 5gal or so I think
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
Certainly any fuel tank must be totally sealed from the passenger compartment in a CAMS approved motorsrort car. I'm not saying that it's impossible but it's not easy. There is a SD1 Rover V8 rally car which is a big hatch back which runs an alloy tank in the back and it has some sort of high tech perspex panel which seals it from the passenger compartment. I am going to lot into the cabriolet option and maybe a 5 speed box.
Geoff
