Results 1 to 10 of 13
Thread: Kjet Fuel Pump Relay
dub be good to me Kjet Fuel Pump Relay 22-03-2009, 12:27 PM
h100vw Would work but you'll get... 22-03-2009, 12:55 PM
paulie71 not a bad idea to avoid... 22-03-2009, 11:00 PM
thestu dude...your wrong. the big... 23-03-2009, 07:45 AM
dub be good to me Don't stress, that post was... 23-03-2009, 03:33 PM
    Sep 2008
    Fitzroy, Melbourne
    I'm fitting an 8v Kjet to my Mk1, but don't have a 'tachometric relay' can I just use normal relay?
    I have a couple of 30A fused relays lying around, but they only have four pins (missing earth). Will these do?
    From my understanding the pins should be (taken from www.diagnostic-assistance.co.uk/mech_inj.htm):
    30 - Positive from battery
    31 - Earth
    1 or 31b - Coil negative
    15 - Switched ignition on voltage (from coil)
    87 - Out let to fuel pump
    What I propose with the relay I have:
    87 - Positive to pump
    85 - Switched ignition on voltage (from coil)
    86 - Coil negative
    Will that work?
    76' 2dr Kjet
    Would work but you'll get fuel pressure all the time. The extra pin on the std relay cuts off the fuel pump when the engine is stopped.
    Getting a prpoer replay should be hard, doesn't have to be a Kjet one AFAIK.
    A digifant one would do the same job I think. Or there's Volvos to pillage.
    Dec 2007
    Somewhere in Melbourne, Victoria
    not a bad idea to avoid anything that doesn't cut off when engine stops. Reason for this is unlikely event of a crash where fuel line is ruptured and pump is still going.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Eastern suburbs of Melb
    dude...your wrong.
    the big relay controls all the pressure. the small relay is just to control current.
    i remember now. the small relay is for the fuel pump (to hold the current) and the big relay is triggered to switch on and off with the coil. when the big relay is triggered it completes the fuel pump relays curcuit allowing the fuel pump to run. only 4 pins on the 30amp relay are used
    i told you to call me if you got stuck!
    Sep 2008
    Fitzroy, Melbourne
    Don't stress, that post was before I spoke to you yesterday. I wired it up as per your diagram
    Still trying to get it started though. I was getting pre-ignition which should be over-advanced timing (and means there is spark?)... so i've been twisting the dizzy clockwise to compensate... expect my battery just died
    I'll let you know how it goes. Expect a call
    76' 2dr Kjet
    Camden, Sydney
    You`ll never get Kjet going without a good battery.
    Charge it up and get anotehr on standby then go at it.
