TCI switch relates to electronic ignition, which hopefully you are running on your car. Its a little rectangular box with 7? connectors that goes to the dissy, the coil and earth and power. You can run kjet with a points dissy, but it has limitations.
Ignition start circuit sends power from the starter when its cranking to the coldstart to chuck more fuel in when starting. If you have the wrong starter you wont have this. You could use a switch if you dont mind the ghetto look
The switch on the throttle boddy is probably the wide open throttle switch. Not used on some kjet cars, depends what throttle body you are using.
The Stu managed to get that setup working, maybe he`d be prepared to help if you get stuck.
Good Luck.
