Results 1 to 10 of 13
Thread: Kjet Fuel Pump Relay
    Sep 2008
    Fitzroy, Melbourne
    I'm fitting an 8v Kjet to my Mk1, but don't have a 'tachometric relay' can I just use normal relay?
    I have a couple of 30A fused relays lying around, but they only have four pins (missing earth). Will these do?
    From my understanding the pins should be (taken from www.diagnostic-assistance.co.uk/mech_inj.htm):
    30 - Positive from battery
    31 - Earth
    1 or 31b - Coil negative
    15 - Switched ignition on voltage (from coil)
    87 - Out let to fuel pump
    What I propose with the relay I have:
    87 - Positive to pump
    85 - Switched ignition on voltage (from coil)
    86 - Coil negative
    Will that work?
    76' 2dr Kjet
    Would work but you'll get fuel pressure all the time. The extra pin on the std relay cuts off the fuel pump when the engine is stopped.
    Getting a prpoer replay should be hard, doesn't have to be a Kjet one AFAIK.
    A digifant one would do the same job I think. Or there's Volvos to pillage.
    Dec 2007
    Somewhere in Melbourne, Victoria
    not a bad idea to avoid anything that doesn't cut off when engine stops. Reason for this is unlikely event of a crash where fuel line is ruptured and pump is still going.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Eastern suburbs of Melb
    dude...your wrong.
    the big relay controls all the pressure. the small relay is just to control current.
    i remember now. the small relay is for the fuel pump (to hold the current) and the big relay is triggered to switch on and off with the coil. when the big relay is triggered it completes the fuel pump relays curcuit allowing the fuel pump to run. only 4 pins on the 30amp relay are used
    i told you to call me if you got stuck!
    Sep 2008
    Fitzroy, Melbourne
    Don't stress, that post was before I spoke to you yesterday. I wired it up as per your diagram
    Still trying to get it started though. I was getting pre-ignition which should be over-advanced timing (and means there is spark?)... so i've been twisting the dizzy clockwise to compensate... expect my battery just died
    I'll let you know how it goes. Expect a call
    76' 2dr Kjet
    Camden, Sydney
    You`ll never get Kjet going without a good battery.
    Charge it up and get anotehr on standby then go at it.
    Sep 2008
    Fitzroy, Melbourne
    Yeah, the battery seems to struggle turning it over.
    I noticed the Kjet 1.8 was quite hard to crank (assume this is because it is high compression?), does it require a different starter motor?
    76' 2dr Kjet
    Camden, Sydney
    Timing is probably out making it hard to turn.
    Kjet does have a different starter, mostly because it needs to send a cranking signal back to the cold start setup.
    Your one should crank it, just make it hard whilst it is out of tune with a weak battery.
    Sep 2008
    Fitzroy, Melbourne
    Sorry wasn't really clear in the last post.
    When I cranked it by hand I noticed it was really tough.
    The engine came with a starter motor, but I swapped to a 5spd (thanks Loon) so I'm not sure which one I put back on. They both looked the same.
    Is there anything I should look for to distinguish them?
    I think the part number may have been different, but just last couple of numbers...
    Also, the brake nipple on the back LHS sheared off (rusty and over muscled by the last guy - my brother ) when I tried to bleed the brakes (I had previously noticed fluid in that corner) leaving some of it behind. Is there any easy way to get it out?
    76' 2dr Kjet
    Camden, Sydney
    Probably both starters are the same. See if one of them has extra electrical terminals on the solenoid.
    A new slave cylinder for the rear is probably the easiest fix there
