Results 1 to 2 of 2
Thread: KE jet to K jet conversion
    Jan 2011
    Cammeray, NSW
    Hi all,
    Some of you might remember about a year ago i had problems with flooded KE-jet ECU. Well it's happened again! Unbelievable I know! It seems every time I get caught in heavy rain the unit floods, fills with water and dies, VW really ballsed up with the design there. Anyway it just seems like a waste of time and money trying to get the KE-jet running properly again so I want to convert it to K-jet.
    What do I need to complete the conversion?
    Thanks, ed
    Perth. WA
    Brushing the dust off, read this first....
    Fuel System
    I changed mine to basic and still more to do.. ( 2E shortblock replacing a good JH shortblock)
    http://kr.flyboybob.com/images/kr2/n...i-probst02.jpg
    I have found its better to use the early dizzy with the vac advance / retard unit instead of the vac only unit that KE uses ( 2 vacuum connections instead of 1 ) Have the dizzy recurved to EG GTI spec also ( or as close as you can to it )
    There are some other better airflowing parts to swap in but it will still run on the original stuff. ( throttle body, exhaust, K&N cam etc )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
